yeah, these lights are a lot of work, I really want to just finish them & move on, I even got a few tiny marks on the chrome rings & was thinking of redoing them with a few more sets, but I think I'm going to just finish them & paint them completely black, then maybe paint the rings silver or something... I originally wanted to maintain the chrome for the rings, but It's tough to not make any marks on the chrome while doing this,especially when you drop them a few times
maybe later I could redo another set of faceplates now that I got all the cuts figured out, the housings & projectors would all already be done so swapping them out later is not too bad
the mirrors aren't too hard to do really, I think most of the reason I'm procrastinating there is cause to mount these I gotta wire through the door jambs too, & I would also have to wire through the doorjambs when I do my system for the door speakers too, so rather than doing it twice I'm waiting till I'm ready to really build the doors in one shot. If you want this mirror mod I already made templates for the cuts in PS, I could give you the file & you can print it & transfer to contact paper, then lay these on your covers & do the cuts... the mirrors are pretty easy really with these templates, all you gotta do is cut a clean hole... I'll post up the files later...
with the drop I just did, it adds a bit of a rake to the stance, you can feel the difference when driving, you can also feel now that the front spring rate is stiffer than the rear now... not 100% happy there. I want to go back in there & play with the rear springs a bit more, cutting them is not as straight foward as the front cause they are altered at each end... I got a few ideas there though... I'll see how that goes. ultimatley I guess air is the best solution, just finding space for a compressor, tank & valves is an issue. rookie, what did you use for the front bags? is there a strut setup that bolts in like the shockwave style setup? the rears look easy enough...
