hey, bumping this up cause I started to show my new tire in the toy thread as a joke, but probably not the best place to continue discussing, figured this thread is probably the best place for this since it involves tires, rims, bodywork, possibly butchering my fx, etc...
so for a while now I've been thinking about moving up to 22's, & I really like the staggered look. being awd, staggered can be a challenge, cause the front & rear have to be the exact same diameter with very little tolerance for differences in tire diameter, front & rear need to be around the same amount of revolutions per mile or the computer will see this as a slip condition & kick up a service light, more like 5 service lights on the fx really.
you'd be surprised how few tires there are out there in 22" with a nice wider rear & a bit narrower matching front that is the exact same diameter or even real close diameter. I looked at pretty much most tires out there trying to find a nice staggered setup in 22's that would be around the right size for the fx. with a nice fat tire out back I want a real muscle look
the tires I came up with looking for a staggered set of 22's are a street sport truck tire. the rears are 315 30 22's & are slightly less overall diameter than stock, but close enough to be fine really. the fronts are going to be 265 35 22's, I would have liked to be a little wider in the front too, but these'll do fine. I tried hard to find a wider tire out back, but can't find anything wider with a matching front, so the 315's will do I guess.
first step in a project like this is to select the tires, second is to build a set of wheels with the exact fit needed to put them where I want them for the body, then, last step is to actually modify the body around the wheels if necessary. it doesn't have to be done in that order I suppose, but that seems to be the best way for me to do this to me... I really don't want to use spacers or anything, I want a custom set of wheels that fit the way I want them to ideally
I ordered a rear tire to see... get an idea of how it fits & how much I want to or need to stretch. surprisingly I think it's very possible to fit this 315 tire completely in the stock wheel well with the right rim, but that would not do anything for my idea of a big fat aggressive body look & I'd still be stuck with stock wheel wells... I'm seriously considering altering the wheel lip & eliminating the whole shadow molding on the bottom of the truck. this is something I always thought I might do someday down the road, but the more I think about just getting one set of wheels the more I think i should do the wheel wells together with the wheels. I really don't want to have to buy another set of wheels in a year or so, bad enough I already bought one set of forged 3 piece 20's, I want just one nice set of 22's....
I really think with the right rim, these tires could be used on any fx, may just need a little triming if they rub slightly if very low, but they can fit with 1/2" clearance to the inner wheelwell. the rim would have to be perfect offset really... these tires will work best with around a 9 1/2" rim in the front & 11 1/2" rim out back....
