- Santa Clarita, CA
- 2005 FX45
There should be no fitment differences between the FX35 and 45 with either the rear lateral arm brace or the tie brace with either the AWD or RWD versions. My only concern is with the clearance of the lateral arm brace for the exhaust piping. If GTspec used a 3in diameter piping as a standard spec then this brace should fit any FX with aftermarket exhaust systems within that spec.
Btw....Ken, you can have my spot on the list as I do not need the rear bars. I only want the 2 front lower tie bar and brace.
