- Los Angeles, CA
- 05 FX35 RWD
Jeff at it again. Great Guy . . Great price.
This a no brainer, & good job Viet!
Finally joined the club Gil. But I think the jury is still out on fit of the lateral arm brace with after market exhausts. Time to batter up Dave.
Nismo brand new 750.
yeah... West Covina is always running that special... In fact... have they ever sold it at the regular price? I seems like it's always $750... they say it's limited... but that was the case back when I got it... well, actually... I think it was $750 INSTALLED... but still
The bracing seems real nice, I will eventually have to get these. But I really need to slow down a little on mods. :burnout:
I was just at WC Nissan, and I also read your old post Ken, the labor is usually $107 and they package all that together in a "special" total price (~$1000) . Its great that they are discounting the exhaust only for $750. I paid a few hundred less but mine was used (good shape).
On the lower bar, the bolts are alignment points with an oval shaped washer. Viet mentioned 'bout marking them so they stay in position, so I did it . . . but everything went into place when I bolted the nutter back on.
Mounting is on alignment points, so if you don't mark the amount of threads exposed, you will be creating your own alignment when you put them back on. If you screw down too much you'll change your camber (it mounts in the camber alignment point right?) or vice versa if you don't screw down enough...I know, I remember reading Viet's instructions... but wasn't sure what he meant... I guess I'll see it when the time comes. (hopefully)
