+1 its a mod you instantly feel makes a difference. The first bars made by Rookie then Doc and Psiclne were cutup to make fit.Yes. The bars are worth having
:call2:if it didn't work, you can certainly return the items for a refund. We're not here to sell you something you can't use.
yeah, I saw that the first ones were cut, what I don't get is if it's corregated inside, & it's cut & welded, how could the center ribs be welded too? I might be able to cut & weld 2 of these togeather? Is it a hollow tube?
might need another one of those rear bars there z1 guys![]()
are they cut through the inner rows? I have a real good welder but I can't see any way to reattach the inner ribs though before welding.. are they just left cut internally?
You just have to cut straight thru. No way of reattaching the inner rows. As long as the weld is done properly I don't see a problem with it. Good luck John, whichever way you decide to go.
it would be logical to think that the bar would be less rigid if only the outside was welded together. maybe you can inject some jb weld in there or something.
This is not rocket science. Just tighten her up as far as you can tighten it. You should have did this on a lift to start with.
