Wait, really??Im going to replace them, BC coils are just as shit as the Megan ones
Sent from my SM-G935T
Trust me... They're WAY better... Noticeable in just the first year of ownership...Im going to replace them, BC coils are just as shit as the Megan ones
Autozone should be able to give you the code
I think it's the MAF (Mass air flow sensor). Just remove it from the intake tube, use a MAF cleaner from CRC, spray it down and air dry.. It should fix the CEL. The sensor was probably dirty.So took it to a shop across from where I was working and the guy did it for free. He said it's a max flow sensor and that's it's common with infiniti and Nissan vehicles. He reset it and said if it comes back he could take care of it for me.
(btw, if you know what this thing is actually called, let me know so I can order the right part).
Could be your browser. Works fine for me... Just go directly to WWW.INFINITIPARTSUSA.COM and click on the links that show up. The only option for you is a 2013 FX37, but that part will be the same for you...Dat - I get a 404 error when I try to visit that site. wtf?
That's very common with the BC and MEGAN coilovers. Just remember to tighten them every time you change your oil... I can't remember what the torque rating for it is though... Anyone?On my fx the top lug nut from my bx coilover got loose and made made an annoying sound when going over bumps
Are the Megan coils going to be for sale? Is it for a 2nd gen? ThanksUGH! Are you gonna rebuild or replace? I just bought a set to replace my MEGAN's and so far they're MUCH better quality over the MEGAN's...
I acutullly have to tighten it every 3 daysThat's very common with the BC and MEGAN coilovers. Just remember to tighten them every time you change your oil... I can't remember what the torque rating for it is though... Anyone?
The MEGANs went in the garbage... They're terrible... And for 1st Gen... I think there's one set of coilovers designed for 2nd Gen FX's... They're pretty much the same design, but specifically made for each of the different Gens...Are the Megan coils going to be for sale? Is it for a 2nd gen? Thanks
YIKES! That sounds BAD!!! Have you checked to see if there's something else wrong to make it loosen up so quickly? Have you been tightening by feel or using a torque wrench? I think I remember it needing to be something like 80-90 ft/lbs so if you're doing less than that, it's probably wiggling free quickly... Also, ever try any blue LOCTITE on it? Will probably help quite a bit...I acutullly have to tighten it every 3 days
