- Los Angeles, CA
- 05 FX35 RWD
Leaky strut? Time to think about upgrade
It's always the 10mm that gets lost. I can't find mine [emoji50]Coming down from snowboarding last night, the fx lost power for a split second. I thought the trans slipped. Then the VDC Off/ Slip/ SES lights lite up. When I got home, I tried restarting the car and it was hard to start. Came to IS to check symptoms. All old posts lead to the camshaft sensor. Took it to autozone and of course got the P0340 code. Bought the bank 1 camshaft sensor, and took about an hour to replace. I couldn't get the dang connector off.. that thing is hard! finally with some needle nose holding the connector down and pulling the sensor i was able to get it off. Then the dang bolt didn't want to go back in either... AND i lost a midget 10mm wrench down in the engine bay to be never seen again....
205,000 miles on the original camshaft sensor.. not bad.
I would wipe the area clean and give that wire a couple more twists to see if it fixes it. What you're looking at is the grease from the inner tie rod ball joint. I'm not too worry about it personally. If it is the steering fluid, it would drip and a I would concern.
PMG
That is steering fluid, but its somewhat normal for a years old. Again personally, I'm not too concern unless I see droplet of fluid there.I don't want to mess with anyth5ing because i still have warranty on it. I informed my service advisor last time in for maintenance and he said that its "normal and its extra grease from factory coming out"
How about the driver side where theres grease too?
Mines looked like that for years and not gotten worse and no issues.Should I be worried about this?
Passenger side
Driver side
Rear wiper stop working, need tires, and suspension gets worse as time goes by.
That sucks! Which coilovers do you have?Strut bearing/pillowballs are seized on my coilovers as well
UGH! Are you gonna rebuild or replace? I just bought a set to replace my MEGAN's and so far they're MUCH better quality over the MEGAN's...BC Racing
