- Dallas, TX
- 2007 FX35 RWD
I think ours are shaped differently yeah? VQ has it up near the windshield. I only removed the intake tube at the TB and pushed it aside to get access.
No need to remove the upper plenum. I use a screw driver with an allen bit to take the lower two bolts out without any problem. The standard "L" shape allen key/wrench will not be long enough.Any tips on TB removal? Those two lower bolts seem hard to get to. I've already gotten the two top ones loosened. I'm hoping to avoid removing the whole upper plenum because I need to swap the TB as quickly as possible.
It should play the DVD audio through the car speakers. It can also be used to play ipod through the RCA's.
to play ipod thru rca, u need the ipod to rca cables right? just plug it into the dvd player in the back? is there a way to tap into the wires from inside the center console?
A few times I've taken my parents car to different quick oil change places I've been asked if I wanted to clean it after the oil is removed but before new oil is put in for like $30 more or whatever it is. If they are asking in places like this I was wondering how common folks here are doing it.
Once I took my dads Cadillac with 50k miles in. They showed me the dipstick it was really dirty they recommended the flush I said no just oil change and they kept pushing I said no. They did the oil change. Asked me to run the engine a little with the new oil. before leaving he comes back showing the dipstick after the oil change and says and I quote. "Still dirty." with a see I told u look and put it back and i left. It was not as clean as brand new oil that's why I was curios. I know my ford dealership has asked me if I wanted an oil flush before too.
Lots of you guys care about oil so much, brands, sending even to labs, etc so I wonder why this is not an added step every so often just to ensure best performance and longevity?
Next oil change go with Pennzoil Ultra. It is a fully synthetic oil that actually cleans the engine up very well. You can find the 5 qrt bottle at Walmart for $27. It is a higher grade oil than Mobil 1. For more info go to the forums on bobistheoilguy.com. I'm running this now for a couple of oil changes to get the most cleaning, then will switch to Pennzoil platinum(still higher rated than Mobil 1 and cost $24 for the 5qrt bottle). Pepboys was having a sale for $22 (with a $7 mail in rebate) for 5qrt jug of PP with a Bosch oil filter.
Interesting...I have heard some say to stay far from Pennzoil because they had a substance called Pectin to their oils, which is what causes the sludge and varnish.
