Is this the final resolution for the spacer/stud debacle?
The SS Debacle has officially sailed! To be honest, I'm glad to see the bitch go. :tongue (2): Installed are H&R 20mm DRS spacers and ARP wheel studs at all four corners. It looks good, I feel good about it, and my center caps still fit. Unless H&R decides to make a 25mm DRS spacer I am not even going to consider changing this setup again.
So, in a little under 7hrs I finished all the FX work aside from the rear pads and rotors. I would have easily finished today but my correct rear rotors are still en route from R1, and I didn't want to install the new pads without them. On that list was an air filter cleaning, wheel stud install (front), pad + rotor install (front), braided ss brake lines (f+r), spacers (f), lug nuts (f), a trip to a local tire shop for lug nuts, and brake fluid flush. Everything went very smoothly aside from disconnecting the hard brake line at the rear driver's side, which required a couple shots of PBlaster and about a half hour of downtime. I haven't burned in the pads and rotors yet but at least they're installed. The forecast calls for sun tomorrow so I'm hoping to get out and give the ABS system a workout. :top:
Here are some pics...
When installing the new wheel studs, one way to "press" them in is to thread the conical lug nut backwards and tighten it down to pull the studs into place. For the sake of my limited socket depth I had to also use another large socket as a spacer, like this:
The new studs are so tough that my impact wrench actually started to pull the lug inside out, and even then the studs weren't fully seated. I had to torque down the wheels several times in order to seat the new studs. The "seating nut" is on the right and a new one on the left for comparison. If you choose this method, plan on destroying at least one nut.
Studs mostly seated, new R1 Premium slotted rotor installed.
New Stoptech pads installed.
I didn't want to drive all the way to the parts store for a caliper piston spreader so I used some flooring shims I had lying around to create enough of a gap to get the new pads onto the new rotor. It worked fine.
Pads, rotors, spacers, Stoptech lines, and lugs installed. Final torque down to seat the studs.
This is how much the WRX studs extend beyond the 20mm spacers when fully seated. Plenty of room for the oem center caps and enough for thicker spacers in the future if it comes to that. Not that I'm planning on thicker spacers...
Here's one of the zinc coated and slotted eline rotors that R1 sent me by mistake. I'm not sure if they'll even fit, but they are WAY lighter than the premiums. I would guess about 30-40% lighter...
