Update on Blue '06 Cluster
Ok it took me a while but i finally had to time to look into this further.
I ordered some extra leds last week to see the both options i had in mind.
First was the one i showed you guys with the blue film over the cauges as it just isn't possible to take out the orange IMO......but maybe i am just to lazy as well. The film showed me that it was possible to get a blue color true the orange.So i exchanged the Orange leds behind the Rev ( LEFT ) cauge with White onces to light up the film as much as possible.
Second option was to use the Blue PLCC-4 leds i used at my current cluster and see what happens, wich i put on the RIGHT side where the speedo is.
First of all i have to give you guys this info in advance before showing the pics. IMO the reason why the +'06 cluster needs an extra ignition power is because i believe it is lit during daytime as well, and dims when you put the light on. I believe the old pre '06 cluster doesn't do that. It's just off and comes on when you put your lights on.
Therefore the up '06 cluster is much brighter to look at and is the main difference in light / color between the old and the new one.
It was very hard to make good pictures wich show you the exact side i see in reality. Often colors and light strenght change on a picture.
Therefore some of you might choose the left side compared to the right, but in reality i think the right side is better.
There you see the illumination is better and keep in mind i didn't change the KM leds in the inner circle so therefore you still see some white/orange color.
The left is approx the same as the pre '06 custer and doesn't stick out that much. On the pic you see the color blue well, in reality you don't. The blue leds are much brighter and the blue film just holds back too much light. Maybe if you used a higher luminus intensity but i doubt it.
Oke some of you would even notice the combo of white and blue on the right cauge, but that just isn't possible to do IMO. And because the left cauge hasn't have an inner circle it just would be to weird having only a white/blue combo at one cauge only.
I've ordered 45 PLCC-4 leds from
www.farnell.com with the part number 1058434 , the same i used in m "old" cluster.
Will finish this up probably end this week and keep you all up to date.
Here some pics:
