Wow... Had no idea you could get after market bushings. Well, that's good to know; I guess I can just replace the bushings on my old one
Sent from my SGH-M919
I called Infiniti parts today. They only sell the entire arm assembly. You can get replacement bushings. they need to get pressed in. likely by a shop.
I found some standard bushings on EBAY, but now I'm having thoughts about getting some harder ones for better road feel. Not solid metal, but maybe harder polyurethane.
---------- Post added at 09:25 PM ---------- Previous post was at 09:23 PM ----------
Maybe Zebra has some. I need to ask . . unless you're reading this?
Passenger side door would not close in -36c weather. I had to lock/unlock the doors a few times before door closed... I'm gonna blame the cold, cuz my jacket wasnt working either
You are great! Voltage : good, Amp : BadProb the battery bc of the cold weather.
Damnit. Got off the on ramp near my house and the CEL came on. Didnt even pay attention to the temp gauge at this point. got off and car immediately went into limp mode, wouldnt go last 1k rpm and wouldnt leave 1st gear. I was holding up traffic so i pulled in to a dead end and i saw my temp gauge at high and there i smelled coolant... had it towed to my mechanic and shes gone for tonight. i washed the hell out of my car yesterday too...
https://vimeo.com/161718112
this is how i attempted to get it off the road
Anyone need to replace their g sensor? The dealership ran the scan with their OBDII and they told me it was related to the AWD G Sensor on my 2006 AWD Infiniti FX35. I brought it in because the SLIP, VDC, and ABS lights are on after I switched from my winter tires to my summer tires. With my winter tires on I did not have issues. Is this coincidence? I don't know. The part number the dealership said I need to replace is part # 47930CL80A. They said to replace and installation would be $2400!! How hard is it to replace the g sensor on a 2006? The dealership said they rarely see this issue. Great!
I've double checked the brake fluid level and topped it off, so that isn't the reason. I replaced rotors and brake pads about 3 months ago.
Are you sure it isn't just a bad speed sensor??? Dealer will tell you one thing and charge you an arm and a leg when it's really something simple. I would put a code reader on it and make sure first.Anyone need to replace their g sensor? The dealership ran the scan with their OBDII and they told me it was related to the AWD G Sensor on my 2006 AWD Infiniti FX35. I brought it in because the SLIP, VDC, and ABS lights are on after I switched from my winter tires to my summer tires. With my winter tires on I did not have issues. Is this coincidence? I don't know. The part number the dealership said I need to replace is part # 47930CL80A. They said to replace and installation would be $2400!! How hard is it to replace the g sensor on a 2006? The dealership said they rarely see this issue. Great!
