Just got this engine fault code: P0441 INFINITI - Evaporative Control System Incorrect Purge Flow
Any idea what it could be? Or explain this in layman's terms what a possible solution is?
P0441 INFINITI
Symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Possible a noticeable fuel odor caused by the release of fuel vapors
Possible Causes
- EVAP canister purge volume control solenoid valve stuck closed
- EVAP control system pressure sensor and the circuit
- Loose, disconnected or improper connection of rubber tube
- Blocked rubber tube
- Cracked EVAP canister
- EVAP canister purge volume control solenoid valve circuit
- Accelerator pedal position sensor
- Blocked purge port
- EVAP canister vent control valve
When is the code detected?
EVAP control system does not operate properly, EVAP control system has a leak between intake manifold and EVAP control system pressure sensor.
P0441 INFINITI Description
In this evaporative emission (
EVAP) control system, purge flow occurs during non-closed throttle conditions. Purge volume is related to air intake volume. Under normal purge conditions (non-closed throttle), the
EVAP canister purge volume control solenoid valve is open to admit purge flow. Purge flow exposes the
EVAP control system pressure sensor to intake manifold vacuum.
