Previous naturally aspirated runs were with very little fuel and nothing extra that added weight.
This one run was with a 1/2 tank of gas, a 120lb lady and other junk adding right around 200 lbs.
Vortech V3 Sci, 2.87 pulley, light weight STOCK SIZE crank pulley, all other existing mod's in tact and a very conservative tune done remotely by Admin. Tuning.
4.4 second 0-60
13.2 second 1/4 mile
I let off at 1110' and coasted to 1320. Sketchy deal so just 1 run. Tires break traction slightly off the line and break loose from 1st to 2nd. Not sure if the front(s) are braking loose to but the smell of burned rubber is detected.
44*, 33% humidity, 30.37 barometric press., 101.91 air density, density altitude -545. No change. No adjustment.
DA Calculator - Density Altitude Calculator - DragTimes.com
Extensively Modified Supercharged and Turbocharged Engines 13.204 @ 105.066 MPH
Remove the added weight, don't let off until after the 1/4 is completed and figure out why it's still getting somewhere between a 2.0 -2.2 second 60' time and I believe this might be in the 12.7-12.8 second FX. Could go with a more aggressive tune as well. Gonna try to get out to Coastal Plains Dragway sometime soon to shoot for this time.
Now, something needs to brake so I have a reason to get the engine and trans built to shoot for 10's.
