how do you like a sound of 850whp fx35
haha .you are very very wrong
---------- Post Merged at 07:04 PM ---------- Previous Post was at 07:02 PM ----------
We are finally back to work on this FX35. We are changing gears... We layed out all the components and have decided to go dual intercoolers....
---------- Post Merged at 07:05 PM ---------- Previous Post was at 07:02 PM ----------
---------- Post Merged at 07:06 PM ---------- Previous Post was at 07:02 PM ----------
Looking at the intake layout we will need larger plenums on each side from what we originally designed.. After some calculations we realize that our original design did not have enough volumn
---------- Post Merged at 07:07 PM ---------- Previous Post was at 07:02 PM ----------
Back to the drawing board on the intake. We also are making custom radiator piping and water piping on the engine. We need to do this because of the turbo downpipe and exhaust
---------- Post Merged at 07:08 PM ---------- Previous Post was at 07:02 PM ----------
The block has come back from Darton with the new sleeves installed
---------- Post Merged at 07:09 PM ---------- Previous Post was at 07:02 PM ----------
100mm pistons and new rings ready to go
---------- Post Merged at 07:10 PM ---------- Previous Post was at 07:02 PM ----------
---------- Post Merged at 07:23 PM ---------- Previous Post was at 07:02 PM ----------
Show Details FROM:
TO:
Message flagged
Tuesday, October 23, 2012 4:28 PM
Alen,
I don’t know if you have checked the Facebook lately but I added some pics.
We have the engine laid out and started to build the bottom end. Darton added the sleeves but did not bore the block correctly, it is the wrong bore size. I sent the block out today to have it bored to 100mm. They had it right on the work order but not on the block. The block was at 96mm (.20 over). I spoke to they today and they said it would take them at least 2 weeks to get to it if we send it back. Instead I am sending it to Orlando to my friends machine shop. Mark said he would get it done within 7 days. That’s good because freight time to Orlando is usually 1 day.
This isn’t really going to slow us down though. We are working on the intake and finishing the exhaust manifolds, wastegate, and dump tube….. Not to mention that the intercooler piping still needs to be done.
Which brings me to my next question. We were looking at it today and want to make our own intercooler. Instead or 1 large intercoioler that has a single exit we are going to make a large dual intercooler that has an inlet and outlet on each. Even though the intercooler will be 1 unit it will act as 2. This will be easier for us to make each turbo feed a single intercooler then feed its own side of the intake manifold.
Really a clean set-up and good for high power.
As far as the engine is concerned we are building it for 900whp. L19 head studs and main studs instead of regular head studs. Sound good?
We are back on your car full time, I have 2 guys working on it.
Stay tuned for pics next couple days.
Doug
Jumbos tranny was not fully build,my tranny is fully build,
---------- Post Merged at 05:59 AM ---------- Previous Post was at 05:42 AM ----------
My tranny build coast was $3400 +750 torque converter,jumbos if am not mistaken coast only $800 bucks.
I could be wrong... I thought his was fully built.
SfmDRuT2
To the Jumbo build thread!
Sounds like he did this:
Higher stall custom torque converter
Transgo Shift kit
L10 5AT internals upgrade
B&M plate/bar transmission cooler with electric fan
Parts & Labor - all installed, fluids included - $2800
Can I join your club? I'm very qualified...
SfmDRuT2
+1:bulgy-eyes:
Concerning the tranny......i got level10's so called "Bullit Proof"internal kit as well. A transmission specialist installed them here in the netherlands, took a look at it and said it was just a overhaul kit with no extra friction material or such. And from what i know they don't offer more then that as well.
It is not that we want it to go wrong if i may speak for others here following this topic. It is just that many companies often claim in theory so much.....but in reality they often cannot keep there word.......as more have already see.......we'll see.....fingers crossed.
That turbo placement is curious. It's so much more work to mount them like that, you have to literally clear everything. And the chances of melting something are so much higher this way. The only reason to mount them that high is purely cosmetic. What's the point of having big turbos if no one can see them right? There are already so many twin turbo manifolds that can support 850whp, redesigning the wheel seems sort of weird.
---------- Post Merged at 10:56 AM ---------- Previous Post was at 10:43 AM ----------
That's exactly what others have said about Level10. No one could ever prove that they did actually use upgraded clutch packs on some of their less common applications. ie, on Nissan Maximas which have a very small following, their "Bulletproof Kit" was just an OEM equivalent rebuild w/ a shift kit. A couple of tranny shops (competitors in fairness) disassembled them and found nothing had been upgraded internally, just the torque convertor and valve body. That was because no one actually made the upgraded part they could use, Level10 just claimed they had upgraded clutch packs. The FX may be different since the tranny is much more common and lots of people upgrade it. But I would never buy anything from Level10 simply because of their history.
I think they get away with it because most people don't make enough power to test their claims. Or if they do, they swap out for a manual. By upgrading the valve body and getting a transmission cooler, 90% of people will be fine even with lots of power. It won't last forever, but it'll work. For instance, on my old car I put 350whp through the stock auto w/ nothing more than a VB upgrade and tranny cooler. Stock it was 150whp. So even w/ 200whp more, the stock tranny didn't blow up with dozens of 1/4 mile passes and dyno runs. Did it slip sometimes, of course, but it survived. So most people who get the Level10 are in a similar situation. Level10 simply rebuilds the tranny and it's strong enough for the power levels they run. Since the tranny survives, no one questions whether Level10 actually did what they were supposed to. FWIW, most OEM stuff is overbuilt enough that it can see extreme duty for short periods of time. So I wouldn't be surprised if a stock transmission w/ VB upgrade survived upwards of 500whp for short periods of time. My friend had a drag Supra that he had to use OEM pistons on at 900+whp for a little while. Sure he had to swap them out every 3-4 runs, but they did hold up temporarily. Same w/ Level10.
+1:bulgy-eyes:
---------- Post Merged at 11:01 AM ---------- Previous Post was at 10:43 AM ----------
Same thing, you paid for the Level10 tranny from them. He bought the Bulletproof kit and had his tranny shop install. In the end, it's the exact same parts that are going in.
---------- Post Merged at 06:03 PM ---------- Previous Post was at 06:02 PM ----------
Finally got the block back from Darton.... Steele sleeves installed, bored to 100mm. Decked block surfaces, and a 3mm raised sleeve to help seal it under huge boost levels..... can you say 1000hp capable?
---------- Post Merged at 06:04 PM ---------- Previous Post was at 06:02 PM ----------
This is a 96mm (.20 over stock) piston sitting in teh cylinder.... Big difference between 96mm and 100mm!!!!!
