This is the process of making aluminum velocity stacks.... We start by cutting the aluminum stock in 3" sections on the band saw
---------- Post added at 07:23 AM ---------- Previous post was at 07:22 AM ----------
---------- Post added at 07:23 AM ---------- Previous post was at 07:23 AM ----------
this is the 3" x 3" section of solid aluminum
---------- Post added at 07:24 AM ---------- Previous post was at 07:23 AM ----------
---------- Post added at 07:24 AM ---------- Previous post was at 07:24 AM ----------
We do this 6 times (actually 8 just in case we make a mistake or if we do it right we will have a couple extras)
---------- Post added at 07:25 AM ---------- Previous post was at 07:24 AM ----------
---------- Post added at 07:26 AM ---------- Previous post was at 07:25 AM ----------
We then design the shape on a computer plus create the process of cutting the part. This simple piece required the use of 6 different cutting tools
---------- Post added at 07:26 AM ---------- Previous post was at 07:26 AM ----------
---------- Post added at 07:27 AM ---------- Previous post was at 07:26 AM ----------
we start by cutting out the inside
---------- Post added at 07:28 AM ---------- Previous post was at 07:27 AM ----------
---------- Post added at 07:29 AM ---------- Previous post was at 07:28 AM ----------
---------- Post added at 07:29 AM ---------- Previous post was at 07:29 AM ----------
---------- Post added at 07:30 AM ---------- Previous post was at 07:29 AM ----------
once all 6 are milled out we go on to the next step
---------- Post added at 07:30 AM ---------- Previous post was at 07:30 AM ----------
---------- Post added at 07:31 AM ---------- Previous post was at 07:30 AM ----------
---------- Post added at 07:32 AM ---------- Previous post was at 07:31 AM ----------
---------- Post added at 07:32 AM ---------- Previous post was at 07:32 AM ----------
We load them back into the CNC
---------- Post added at 07:33 AM ---------- Previous post was at 07:32 AM ----------
---------- Post added at 07:34 AM ---------- Previous post was at 07:33 AM ----------
Then we cut the back side and check fitment. If everything is accurate we cut to desired length
---------- Post added at 07:34 AM ---------- Previous post was at 07:34 AM ----------
---------- Post added at 07:35 AM ---------- Previous post was at 07:34 AM ----------
This is the finished size
---------- Post added at 07:36 AM ---------- Previous post was at 07:35 AM ----------
---------- Post added at 07:36 AM ---------- Previous post was at 07:36 AM ----------
this is the back side of the finished product
---------- Post added at 07:37 AM ---------- Previous post was at 07:36 AM ----------
---------- Post added at 07:37 AM ---------- Previous post was at 07:37 AM ----------
here are all 8 pieces.... Now we will weld them into the intake plenum
---------- Post added at 07:38 AM ---------- Previous post was at 07:37 AM ----------
---------- Post added at 07:39 AM ---------- Previous post was at 07:38 AM ----------
the velocity stacks fit perfectly onto the 2" OD pipe
---------- Post added at 07:39 AM ---------- Previous post was at 07:39 AM ----------
---------- Post added at 07:40 AM ---------- Previous post was at 07:39 AM ----------
this is how they will fit
---------- Post added at 07:41 AM ---------- Previous post was at 07:40 AM ----------
---------- Post added at 07:41 AM ---------- Previous post was at 07:41 AM ----------
The velocity stacks will be flush mounted and welded into place like so.....
---------- Post added at 07:42 AM ---------- Previous post was at 07:41 AM ----------
