Saleen00_227
I may or may not do this mod but I'm curious to know if just grounding the brake wire will allow the DVD player to play. For instance, wife is driving and stops to run into the store. I'm in the passenger seat and to pass the time, I select DVD player to watch a movie. Instead of climbing over the console to depress the emergency brake, will just grounding the brake wire allow the DVD to be watched? Sorry if this is a hijack but it seems it's related to this mod. Thanks.
BTW, could someone PM me the info regarding the 1st vs the 2nd method? Don't have enough post to PM Saleen. Thanks.
Yes if you are standing still and would like to view the dvd without applying the E-brake, just grounding will work. But once you start rolling it will not allow you to watch as it is sensing speed.
---------- Post added at 05:38 PM ---------- Previous post was at 05:34 PM ----------
^^^^ You would need to put a switch on the VSS wire and ground the e-brake wire.. I need to get a hold of the service manual for the 2010's as the connectors in the back are different.. I should have it in the next few days and I'll post it up. BTW, doing this will allow you to not only watch DVDs while in motion, but also input commands on your navigation.
Just the DVD unlock: can try what this guy did on the org.. last entry
http://www.infinitifx.org/viewtopic.php?f=61&t=20799
I have the manual for all 2009-2010. Let me know if you would like me to find the wire for you.
