Me and my friend successfully did on it on the NAV09 FX50s... Everything seemed good until I tried it again later tonight, and it seems that the airbags light were flashing. Also the passenger airbags seems to be off even with someone sitting with seat belts on....
Maybe I turn on/off when certain thing were unplugged?
Any advice will be appreciated, thanks
EDIT:
Reset the ECU and everything is okay now!
did this:
1. Turn ignition switch from OFF to ON.
2. Within 1 second after air bag warning lamp is on for 7 seconds and turns off, turn off ignition switch.
3. After ignition switch is turned off, wait for more than 3 seconds.
4. Repeat steps 1-3 two more times (3 OFF to ON sequences in total)
5. Turn ignition switch to ON.
6. Turn ignition switch OFF and wait for more than 1 second then turn it back ON.
EDIT2:
I have 2009 FX50s with Nav, so the way the mod was done is the same thing as this picture (minus the lower part):
I don't have picture but it is VERY similar to the 2010 with Nav one (FUSCHIA, not light pink, you can't miss it) Made a button next to the auto/sport button to enable/disable the VSS (will put picture another day0:
and for the ground it is exactly this picture (Cut off and grounded):
Something we noticed when doing the Mod is that the ground thread really needs to be cut off and grounded (can't be grounded and plugged)
Also, in order to watch the video you must absolutely have the VSS switch to off. The video detects both the VSS and the Ground sensor.
hope this helps for people with 09 Nav
---------- Post added at 01:11 AM ---------- Previous post was Yesterday at 10:54 PM ----------
do you guys think by putting a rocker switch right next to the auto/sport switch will make the dealership make my life harder by b*tching at me saying warranty is void etc?
EDIT:
did this:
EDIT2:
