You think just replacing the battery will fix the fluttering RPM problem just after start?
I guess there is no harm in trying, Ill do the battery and if the problem comes back then I will know that it is the AC amp.
Hey guys, i had a few issues with the fx this past weekend. It was -4f to -22f here in toronto and my car had a hard time starting. it took several cranks to start. Also my fx couldn't detect the intel key in the mornings. once it warmed up, i had no issues. car started fine, the key was detected.
When i was driving , i had 5 codes pop up. one was p0420, then i forgot the rest. I reset it on unichip and the codes never came back.
The last things i did to the fx was change the battery (kirkland battery with high CA). and a car wash ( bad idea in the cold)
Im thinking of swaping my oem battery back in to test it out but want to see any one experienced this.
Also my dumb fan blower motor squeaks but thats least of my worries right now. prob needs some lube
Change the battery in the key fob before you do anything else. I had very similar problems and it turned out that my key fob battery was the culprit.
EDIT: Also with those kinds of temps are you using the block heater?
no i didn;t use the block heater. i was on vacation to the slopes. i tried both keys i had. both coudn't be detected. BUT when the car been running for a while ( say stop for a washroom break), it will recognize the key.
I replaced my AC amp this weekend. As everyone has already said, it's an easy install and it fixed the problem. One odd thing though - I replaced the battery at the same time (it's the original battery and winter is coming- really just a precaution). I noticed this morning that my speedometer is reading high - like 4+mph high). What's really weird is that the intelligent cruise is correct. For example, if the analog gauge says 65 and I set the cruise, the display will say that I set the cruise at 61. I confirmed with a speedometer app on my phone that I really am going 61.
I previously had the speedometer/mileage recall fix performed. Anyone have any thoughts or have similar experiences?
I just replaced my AC Amp and noticed the exact same thing as you. Did you ever figure it out?
