There is indeed one screw for the glove box behind the side kick panel. I, too, cannot remove the side kick panel; something is holding it near the top-back edge. I cannot access the right screw for the glove box that's behind that panel. How do you get to that screw without removing the side kick panel?
---------- Post added at 11:31 AM ---------- Previous post was at 11:05 AM ----------
Never mind. There are two metal clips at the top back of the side kick panel that require a LOT of force to pull out. I used a long screwdriver as a lever close to the rearmost clip and was able to remove the panel. I reinstalled it with SILICONE GREASE on the clips!!!!
I looked this procedure up already and thought this is really complicated, a little surprised, i'm an HVAC designer and think this should be easier ... anyway, I decided not to replace the filter, mine is missing, and I can't see that it makes much difference ... car smells fine, at most the evap would need to be cleaned some, but i have good air
