Zebra will probably know.Anyone know where to buy the H&R spacer nuts that come with the bolt on spacers
Thanks
do you got gtspec strut bar? could the fx flexing and it hitting the hood. im pretty sure thats what is causing my poping noise
I had something similar and it was actually the latch on the hood had come loose. You couldn't see the movement, but it was the same popping sound when going over bumps. Mine sounded like the passengers side, but could be the same issue.
Anyone???Anyone know where to find the black aftermarket infiniti fx35 grille in black??? I used to see them everywhere now that Im thinking of getting one I cant find them anywhere.
Yes those. I've looked on there but cant find them or on amazon.I assume you're asking about the badgeless grille? They were all over ebay for a while. Might still be there.
B2 auto designs was advertising them in this thread
https://www.infinitiscene.com/searc...bolt-on-wheel-spacer-for-Infiniti-Application
The link says product not found
But maybe msg them to see if they can still get them
Good for you Jonas, glad you are going to start changing your own tires and wheels.Bought a compressor for closing my pool, clearing out my sprinklers, etc:
http://www.sears.com/craftsman-33-gallon-vertical-air-compressor/p-00916572000P
Thought now I would get the tools for just being able to switch out to winter tires and rotate when desired.
What would you recommend for a good reliable accurate and affordable torque wrench, impact gun, and jack kit be?
