- Miami
- 2004 Infiniti FX35 Supercharged
Did you reuse/heat the glue to stick the emblem back on?
I didn't reuse the glue and removed the emblem without heat. You can use the 3M Emblem Kit, I used automotive all weather glue.
Did you use primer on the emblem before wrapping?
I used 3M primer
Or simply cleaned/alcohol wipe before applying?
Also cleaned with alcohol
and is the grille's emblem the same way (glued)?
I have badgerless grille
I used 3M primer
