The Random Question Thread
Where did u fill up? Maybe u got bad gas?
Shell station by school. I filled up there yesterday morning and today also. I usually go to a different one because it's cheaper but they should have the same gas.
I don't know if too much/too little oil could cause it.
Low oil level could make a sound like that. Is it a rat-a-tat-tat, or a knock-knock-knock?
Only at idle? Or so faint that you can't hear it at even low speed?
It's only at idle or a little gas in neutral. Definitely a knock not a tick. Kinda sounds like a midget playing the bongos in there. Dadada da da and just loops like that. I'll check the oil when I get to LA since it will have to sit for a bit.
Yeah. 99% of Infiniti dealers will put it through a throttle body cleaner machine thingy which doesn't do much and sucks. U are better off cleaning it yourself there is a DIY and its pretty easy I've done it or take it to a mechanic that cleans it by hand. This is what the head mechanic at my Infiniti dealer recommends. Said he has seen the results of the machine afterwards and it's a waste of money and cleaning by hand is the same price or sometimes even cheaper depending in number of throttle bodies.
Thanks Jonas gonna see wat the dealer says gonna get her back if it still persists ill clean em my self
Sent from my iPad Mini
I just picked up some eibacks springs for my 04 fx35 couldn't pass up on the deal $125 new for all four. How many coils do I cut in the front to match the rear hight
What really is the purpose for the plastic covering the motor? do some of you take it off?
---------- Post Merged at 08:48 PM ---------- Previous Post was at 08:48 PM ----------
Where?
