- Toronto, Canada
- 2008 fx35 AWD
personally i would buy led ones. ccfl tends to give you issues after a while ( ballast needs to be changed etc) Id go with leds.
i would just do the fronts its just bolt on
Wow... Are you already bored with your v8?
Is it possible to Supercharge the 1st gen 45? If so, who's done it?
If the rpms dip below 500 at a light does it have to do w the throttle body ? fx is at dealer to check it out since its 51,000 :'( but told me theyll cover it under it. Also where can i find good info on extended warranty?
