If you are going to do this on a regular basis, why not get the cheap vacuum pump. You don't want to go to the Dealers each time you want a sample. Or what TC said, crawl underneath and loosen your filter to get a sample.
I know someone that wants to sell me a cat back exhaust from a G35, I own a FX35. My questions is would that exhaust fit my FX, are they similar or should I just buy one brand new and skip the headaches if there are any? Does anyone here know, would love it if you help me go in the right direction with this one.
Are you concerned because the rubber bushing is cracked?
Sent from my DROID RAZR
yess
Do yall think 31mm spacers on the front would stick out too much or would it be flush? BTW I have stock 20's, I already have 25mm all around but the fronts are still a bit tucked in, so I wasn't sure if 31mm's would be too much?
Sent from my HTC_Amaze_4G
Don't forget to tie something heavy at the end of the string so you get a real plumb line, but not get in the way of the wheel/tire to skew the measurement :wink (2):Measure it by hanging a string from your fender...
I'm using a 24 gauge wire (for the $20 sub boost), but was only able to find 18-22 gauge wire taps (http://www.radioshack.com/product/index.jsp?productId=2103500). Is this okay to use? thanks!
Sorry for my electrical noob-ness... first circuits/electronics project ever
I've been trying to start a new thread in the FX community section and keep getting this error. I am posting some text with 3 image links...nothing out of the ordinary.
The following errors occurred with your submission
Also, have you guys noticed the other several issues (I have for awhile now but figured I'd be more vocal this time)? If you reply with a quote it turns all the font to black and then when you make it white so you can see it posted, then you can't see it in the preview. It's like a vicious nightmare. Then if you copy from a thread some text or in other situations, the font can get really messed up: color, size, everything. Also I notice after you preview images, it removes that tags surrounding it that allow you to click to enlarge it...some people don't want it automatically enlarged all the time and this happens if you preview a post with images....I could go on....these issues were none existent before the site upgrade. ugh
- The number of tags you tried to add exceeded the maximum number of tags by 2.
