- Toronto, Canada
- 2008 fx35 AWD
will the towers work as blinker lights after the swap? is it compatible since i hear leds dont work for signal lights without a resister ?
No they cannot use as blinkers. I have tested them.will the towers work as blinker lights after the swap? is it compatible since i hear leds dont work for signal lights without a resister ?
That's exactly where you will use thes bulbs if you do the swap. In the turn signal location. They'll give off as looking like you have dual headlights
The bulbs that Arturius have do the same thing, they burn out or become very dim. I've been running Cree bulbs in my car the last week ever since I modded my headlights, using a totally different approach and setup. So far so good, but it's only been a few hours of actual run time. I'll be updating my testing in a few weeks. But all I have to say is it looks fantastic with the TSX-R clear lens swap.
