Ray's Boost
raymond
Netherlands
FX35 RWD
So finally my buddy Jumbo finished his F/I project and his FX runs great. That was the sign to start my own tread of my F/I project witch I am working on now for over 1,5 years already.
A lot of you already know I am working on something but the whole economic BS set me back quite some and I didn’t want to start a tread when not seeing to end in sight.
I called this tread Ray’s Boost as a thumbs up to my buddy Jumbo as he really helped me a lot with my own project but also want to thank Turbocad for helping me out a lot with advice and all other things….you know what I’m talking about John J
Also rookie must have been getting crazy with all my questions, but hey sorry guys you all seem to be the once with the most knowledge and experience on this forum concerning these projects haha..!!
So my story begins with a client of mine driving a 350Z and purchased a Single Turbonetics kit. He drove with it for a while without issues on a stock engine. But as the guy he is he wanted more and increased the boost pressure each time at the point he got head lift. He then sold his complete shizzle to another guy I knew with a 350Z Drift car. Who wanted to get 500-600 Hp out of it.Rebuild the engine with eagle rods….ARP bolts….ACL bearings etc, bought a GT35R turbo and watercooled intercooler as drift cars don’t make much speed to cool the intercooler that well.
Then he put a KMS stand alone computer on it and a business colleague of he would come by to map the whole deal.
Long story short no good tune and the engine detonated.
He then talked to several guys and wanted to stroke it……sleeve it…..and go all out till he heard the price…!!
He then decided to went the easy and reliable way and put an LS3 corvette engine in the drift car witch still runs great…!!
So that is when I came into the story. When driving for fun and on the street with my FX I saw the potential. I got a good pricing on the whole deal and bought it incl. both turbo’s and a Kinetix intake manifold.
I could have gone for the easy way and put the stock Turbonetics kit on my own engine, but know who I am and would have always doubted how it would run with the GT35R turbo.
So I decided to go all out within my budget in performance and estatics as well.
Bored the short block and put in Low compression 8.8 Wiseco pistons in. The guys before me stayed at High compression and this will decrease turbo lag but will increase change to detonation as they found out J
Here are some pics of the block and progress in the beginning. I painted all parts Matt black with a high temp paint. Not that you would see much of it. But when already having it in my hand I thought I’d might as well take care of it. Ok pics…!!
More Pics
Further i read about the Issue wich Jumbo had with his OEM headers and lett mine get X-Rayed just in case :wub:
Also in the picture here you can see the Cosworth Oil Baffle at the cranck. This is mostly used for extreme cornering so the oil doesn't flow away from the cranck to fast and keep it lubricated.
More Pics
So again knowing myself and reading a lot of topics and looking at many websites of tuners offering parts for the VQ engine I soon realised this whole project would take far more time then I expected as I stumbled on to many parts I wanted. And with the GT35R on I also knew I needed to upgrade several other things like the tranny…..cooling…..fuel….
So again I had a lot of help of Jumbo’s treads as he kinda did the same as I want to.
Outter then a few parts I need to buy here is the list of technical parts and stuff I have as following.
Engine:
  • Bored short block to 96mm
  • Wiseco Forged pistons low Compression 8.8
  • Eagle H-Beam Rods
  • Heads semi ported and Valve seats worked on
  • ACL Race Bearing
  • ARP Bolts @ Head, Girdle and Rods
  • Brian Crower Valve Springs
  • HKS 264 Degree Cams
  • Cometic Head Gasket
  • 850CC Injectors
  • AAM Stage 1 Fuel & Return Lines
  • Okada Ignition Coils for F/I Spec
  • Okada Plasma Lift ( Okada’s version of the HKS DLI-II )
  • Nismo Thermostate
  • Cosworth Plenum intake gasket
  • Sikky Plenum intake gaskets ( at the heads )
  • Kintex SSV Intake Manifold
  • Cosworth Oil Baffle
  • Greddy Oil Pan
  • ATI Cranck Pully
  • Unorthodox Acc Pully’s
  • Turbonetics Single Turbo Kit with an Upgrade to a GT35R
Around the Engine:
  • Pathfinder Cooling Mod
  • PWR 56mm Alu Radiator with Transmission Cooler
  • GTM Fan Shroud incl. dual 14” Fans ( soon )
  • B&M Oilcooler incl. Fan & Thermostat
  • DEI Titanium Turbo shield kit for the GT35R
  • DEI Titanium Exhaust Wraping
  • Greddy Water temp block
  • Injen Carbon fiber Heat shield for the Air Filter
  • Level 10 Transmission Internal Kit
  • Level 10 Oilpump upgrade ( soon )
  • Level 10 Valve Body Upgrade (soon)
  • Edge Racing Higher Stall Torque Converter
  • Euro Spec rear Pumpkin Incl. LSD
  • Whiteline Urethaan Diff bushings
  • Quaife Limited Slip ( soon )
  • Haltech Platinum Pro ECU Incl. Boost & Wideband control
  • Innovate Wideband Gauges
  • HKS Camp 2 incl. all sensors ( soon )
  • Samco Blue water & intercooler Hoses
  • Perrin 600 Oil Catch Tank
Estatics:
  • Timing Cover & Valve Covers in Custom Blue paint
  • Several Parts Chromed or Polished
  • Goodridge Couplers and Stainless hoses
  • Prolock Billit Hose Clamps for intercooler and water
  • NRG Alu Power Steering Tank
  • NRG Grounding Kit
  • Circuit Sport Radiator Tank
  • Wire Tuk ( when Building )
More pics:
So i also have quite ome pics off the cool stuff i have lying around here. On a lot of projects you often don't see what went in. I try to document this build as much as possible, also because it is has become quite a impressive project for me as well.
Will i ever do it again this far......??! :cool:
More Pics:
Its like christmas man. NICE! Cant wait till the build is done.
and lolol at x-raying your headers. ahh... the things we do...
Haha yeah but i have been looking at these present way to long......time to start playing with these toys :laugh:
X-Ray a buddy of mine did luckely. Quite expensive to do he said. But as any things goes....they say....it's not who you are.....it is who you know :wink:
I hope to finishe this project end of the summer. Thing is with needing to airfreight in all these parts and VAT being here 19% i think you can gues doing such a project will set you back a bit more then living in the us.....unfortunalty.
Example i purchased the sikky thermal intake gaskets. They were around 60 USD.....shipping was another 60USD. And then i had to pay 19% tax and customs :eek:
And that's only with a couple of gaskets.
On the other hand due to my bussines i was able to get a good deal on some parts. But in the end far more then i thought it would costs.
My main problem is that i want to do it all at once......like Jumbo he did his tranny in advance.....he planned ahead. I could have done that also but it wouldn't have saved me money at this point so decided to do it when i take out the engine.
Thing is i need to have budget before starting the real build. Once the tranny is out i have to bring that to a local transmission builder and get that done......so...labor...
Then i have to ship the valve body and the tranny oil pump to get that done.
Then also i want to paint the inside of the engine bay......flat black..just to give ita detailed touch.
And the finally the tuning/mapping begins wich will be another labor.
So before i even can begin i need to have these costs covered......that is the next hirdle i am facing right now and buying some final parts.........:confused:
Good choice not to run the TN kit. They tend to be frowned upon due to common issues.
Uhhhh well......i am going to use the turbonetics kit :err: That is the whole kit in stead of the injectors....ecu mapping.....T60.1 turbo.
So the intercooling and exhaust piping.....BOV....Wastegate and Intercooler i will be using.
If i wouldn't use that, there wasn't really any use of buying that whole engine & parts.
Any knowledgeof those common issues stulax...?? :eek.:
