Tried to install the 4 pin tow harness. Looks like they changed the connector in the 2013?????? They do not show a different part number. :at-wits-end:
Thanks Zebra! I just ordered them so we will see how they look. I think my GTRs HAVE to at least have these behind them.
---------- Post added at 09:32 PM ---------- Previous post was at 09:31 PM ----------
Should I use new pads with them or can i just replace the rotors?
Pads are not terribly expensive. I would go with new pads. If not, your current pads should be fine Dave.
Should have gotten my GTR's mounted today. Instead my tires did not come, so hopefully tomorrow. If it is not tomorrow I am going to drive to the discount tire and absolutely flip shit because the tires were meant to be there tuesday.
On the plus side, I picked up a set of gold Blackworks racing lug nuts and a set of gold blackworks racing fender washer kits.
The plan is to do a gold BBK in the near to immediate future. I definetly missed out on Zebra's BBK for sale. But unfortunately I probably would have been killed if I had bought them then.
Dyna mat'd the trunk while I had everything out. Now off to the dealer about the wiring harness.
---------- Post added at 01:50 PM ---------- Previous post was at 06:41 AM ----------
Changed out the rear reflectors to the lighted version. Wired them thru the 4-pin trailer harness.
Nicely done to wired them through the trailer harness. I heard the side clip that holds the side of taillights was very tight on the 2nd Gen.
With the harness, you do not have to remove the tail lights at all. It is all done from inside the vehicle. You have to take out the back interior to access the wiring harness. And you have to drill a hole for the wiring to end up outside. Other than that, it was a piece of cake.
Got the Stillen CAI installed and did all the ECU and Idle Air Volume Reset. Black Mamba sounds fierce...
