- Houston,Tx
- 2007 Infiniti FX35 AWD
How did you get those bolts off? Cheater bar?
I would too in saying "merry xmas" after swapping out your rotora's with stock calipers! =)
Safe travels buddy!
I'm gonna kick your ass if I found out you passed my area without visiting me on your way to Grand Rapids. I assume you had your car transported directly from NY to GR.![]()
Mine came off with a standard 1/2" socket wrench. Unless you've got significant corrosion, they're not THAT tight.
Did you have to get an alignment because I did after installing the rear lower lateral brace, I hope I dont have to do it again after installing the rear lower tie brace tomorrow. BTW looks good! Im getting the front lower tie brace next.
^^your FX looks great.
Dam looks real sick with the GTR's
Andy, I highly recommend this product called LPS3 for protecting your coilovers. http://www.lpslabs.com/product_pg/corrosion_pg/LPS3.html.
We used it at the Nuclear complex I worked at for protecting some parts for long time storage. I also have used it around home on parts. I also recommended it to a few friends on another site for their coilovers and they were very satisfied with the results.t.
That your man cave Andy? Looks nice and spacious in there.
Looks really good Jonathan :good:
Hahaha, not really a man cave. Not spacious enough at times. I have been thinking about expanding it to my lot line which will give me about 8 foot in width, but not enough for a car.
Be sure to check with your local building department about the setback laws in your area. In my city you cant build anything within 5' of the property line.
In ny you can't build anything within 3' of you property line
