- FX
it's a non-NAV 2010 vehicle
:smile (2): I purchased it a month ago
From the picture try the Far Bottom Right plug. Wire 92 (RED) Is the Speed sensor, Wire 93 (BLACK) is E-brake that you have to ground. Should be the bottom left two wires on that plug
Had this problem when I did mine.. Saleen is correct. For a 2010 non-nav the wires are located on the connector that is on the opposite side of the 3 black antenna wires. If you're sitting in the car and facing the front of the AV unit, the plug is on the bottom left of the unit. Cut the red and ground the violet (wire coming from the plug)...
Cheers.
