- brooklyn, ny
dude, i'm not recommending anything, just pointing out the facts... there are things you'd get with a ts that you won't get with a dyno tune & there are things you'd get with a dyno tune that your not going to get as well with a remote ts tune, so both togeather would give you the best of both... in the end your spending $$$, na it's hard to say if it's so worth it unless you got some serious breathing mods, more than just an intake & cat back I'd say...
another thing that ts gives that you won't get elseware I believe it there tranny bump too, they in there flash raise the tranny presure too for firmer shifts & a little less heat build up is another by product of the higher pressure, that alone is probably worth the $250 tuner flash, especially when you combine it with the 100% throttle...
