deciding what to get next
yeap, all's well, getting ready, hope I can get all the obdII modules to play nice with each other & runn it off the stock hr box & then osris it up , trying to avoid having to do a 3k+stand alone, that's really gonna cut into rotrex funds :tongue:
you guys suck. hahaha
but yeah i hear kakumei headers are crap..........
im pretty positive nismos are one of the better ones out there for me (correct?) so im going to aim to try and find those....
nobody's answered about the engine damper yet though :-/
and im pretty sure that im going to go ahead with a TS tune unless i find a place enar me, becasue i did some "searching" and apparently it's worse to just piggyback then get a TS tune, even if they cant have my fx on a dyno....?
---------- Post added at 07:01 AM ---------- Previous post was at 04:59 AM ----------
anybody? haha oe is it too early?
Engine damper doesn't do much for performance. If you are using stock motor mounts, they flex because they are rubber. They are supposed to because they are isolation between the engine and the chassis. When you add an engine damper, all you are doing is tying the engine to the chassis in another location, with another "flexible" member that is designed to stop the engine moving around on the motor mounts under load. You might notice a little bit of feel difference, but I doubt it would translate to more horsepower. If anything, it would improve your acceleration curve a bit (you would accelerate from 0-60 tiny bit faster) but probably not in a measureable way.
Dampers are really meant for high horsepower applications. If no FI, then probably not worth it.
Also - Stillen actually recommends AGAINST their headers IF you have the Stillen exhaust. You might want to ask customer service WHY that is and if the same issue would happen with other header/exhaust combinations. Plus, if you EVER go FI, you'll trash (sell) the headers.
okay, thank you.
my translation for the damper still is that you can feel a difference and it helps accel....but the question remains if the g35 or 350z ones would fit an fx?
and for headers, im trying to find a set of nismos because i hear they are great....
and that apparnetly is a good add-on for NA and will go great with my nismo catback
Lol brand whores. There are plenty of quality headers to be had for less than the Nismos. If you think they are worth paying 2-3 times the price, then go ahead, maybe they are.
okay, thank you.
I've never seen a dampener on an FX so I'm really not sure how much you would feel it. And as to G35/350Z dampeners fitting - probably not. Since the attach point on the engine is the same but the chassis is completely different from one car to the next - I don't know where it would attach to the FX chassis. BTW - you can do this exact same thing with solid (polyurethane) motor mounts and NO dampener. I have a thread on this - I'm running solid mounts right now. But I personally don't like the vibration this translates into the seat and how loud it sounds inside the car. I plan on going back to OEM mounts. After FI, I might look into a dampener if I keep ripping mounts - like some on the scene have done. That way I can keep the quiet FX feel, but take advantage of the stiffer drivetrain. I just don't know if a dampener would also allow vibration to be felt and heard more.
yeah i saw the threads but i figured the nismo headers would complement my nismo exhaust the best and sound the best, and impretty sure they would be one of the best performanc eones
---------- Post added at 07:45 AM ---------- Previous post was at 07:44 AM ----------
yeah i guess it wouldnt necessarily fit then, i was just curious because all theones i read about on z and g forums said they felt it alot on the butt dyno....
J, couldn't read the whole thread (obviously I'm at work now) but here's my take on some parts, esp since you said you value hp/tq below 4500..
1) Lighter wheels:
- Believe me or not, it will improve your FX's agility most. Get some lighter 20 inchers and get rid of the 20s or keep them to put it back later
2) Lower profile 20" tires:
- Smaller tire diameter = better gearing. All in my honesty, I loved the 275/40/20s with stockers. They looked ugly though, even with H&Rs. I say get wide & light 20 inchers with 295/40/20 tires. It will impact your odometer a little but not much unless you really hit the road a lot (which I doubt you do)
- DON'T go with 22s unless they are high quality light wheels. My Spideros look great but you could easily feel the engine bogging at low range with those.
3) Get a y-pipe to complement your nismo:
- You already covered this. Either get Kakumei or get Nismo y and extend at the arms rather than the collector
4) Get headers:
- This will improve starting from 4000. Not exactly low range power but you'll love the sound.
- Nismo are good but the difference between them and some other good ones are very very small.
- Whichever one you get, get stainless and get it coated. The stock heat shields around the stock headers won't fit after you get your aftermarket ones and WILL heat up the air under the hood. You don't want that really..
5) Lose weight :tonguey:
1) Lighter wheels:
4) Get headers:
i was thinking about lighter wheels but i already invested so much into the 2 sets ihave now... :-/
headers cost alot to install too haha
and the ones i want are MONEY
and yeah im trying to do #5
---------- Post added at 11:46 AM ---------- Previous post was at 11:45 AM ----------
after a few phonecalls i've decided im going to get either the kakumei or nismo y pipe, instlal that, then get a..
TUNE
im talkign to a close shop with a dyno about pricing (they want to use a cobb piggyback)
orrr may just go with the technosquare then elave the fx alone untill i ave money for serious things
---------- Post added at 12:12 PM ---------- Previous post was at 11:46 AM ----------
time to call technosquare/ local tuners
i
TS mail-in service will only adjust A/F ratio and nothing else. Not worth it.
1) Lighter wheels:
:tonguey:
Some time ago I read a thread in a wheel write up by a guy who owns a sport wheel shop and races mazdas. EG3's write up made me think about it. I searched and finally found it, solid reading. He was a little pissed in his write up, I took it upon myself to remove some of the more excitable comments.......Please note this article is NOT directed at you JB but rather at some dude this guy is irritated at with a mazda 3-just good information.........This article or the reasons within are why I am still running stockers. I have resisted buying wheels for my FX because I can't afford the uber expensive lightweight wheels. When I can Afford to roll out the lightweight wheels I'll go with 22's but for now I'll stay with performance mods.
The average 20" wheel is 35lbs. The stock 16" wheel combination WITH tires is 39.4 lbs. So you're almost as heavy before even mounting tires! I tried looking up tire weights, and realized that no respectable manufacturer makes the size you would need. So you're forced to buy s**t tires. Kuhmo doesn't even make the "MX" in a 20" size because no respectable performance driver would be on 20's. But their 712's are available in SUV sizes, and the 255/35/20 is 30lbs. T1-S's also come in that size, but no smaller width. These are essentially SUV tires, they're heavy because they're designed to support a lot of weight. Falken doesn't even make Azenis in a size over 17" because again, no respectable racer (autocrosser) would use wheels larger than that.
The only reason to run large wheels is to run large brakes, and the 3's brakes are completely adequate for track use (when used with track pads) even under 16" wheels.
Anyway, back to weights. You're going to run 35lb wheels with 30lb tires, totally 65lbs compared with 39.4lbs stock. This is not like adding a 200lb subwoofer in the trunk (which is pretty stupid), this is far worse. The thing about wheels is you have to spin them, and that takes much more effort than it does to move an object that isn't spinning. You're dealing with the polar moment of inertia.
I won't bother explaining it since I doubt you care (and Crossbow already touched on it), but here are some numbers for you.
In fact, just for fun I looked up how much straight-line performance you'd lose by switching from 16" wheels to 20" wheels if the wheels weighed the same. It'd be about like adding 200 static weight to the car, which would take an additional 11ft-lbs of torque (roughly 15hp @ the rev limiter) to compensate and get the same acceleration as a stock car. That's bad enough.
But no 20" wheel is as light as the stock 16's. Your combination will weigh 65lbs, remember?
That's like adding nearly 800lbs of static weight to the car. Think about that number. That's almost 30% of your car's entire weight. In order for the car to accelerate like it did STOCK, you'd have to gain back 42ft-lbs of torque over the ENTIRE rev range. At the rev limiter, you'd need to be making 55 extra horsepower. Not gonna happen without forced induction. So basically, you'll need to supercharge your car to keep pace with a stock Mazda3 on 16" wheels.
Bling bling though, right?
Now you know why people with big rims get laughed at. Clowns wear big shoes too, but they're supposed to be funny.
Oh, and that's assuming you get the tires to fit in the first place, and then manage to make it over a pothole. You should aim to keep the volume of air in a tire constant when plus-sizing, which is why you should always upgrade to a wider wheel and wider tire when plus-sizing (a reason why Porsche uses hollow spokes!). Due to fender size constraints, you can do neither, and your brand new $4000 wheels will be bent in no time. The sidewall on 35 profile tires has to be very soft to be compliant, and your car will look like the rims are touching the ground. You know the look- like the tires are low on air. Take a turn and it looks like the rim scrapes, hit a pothole and the rim breaks. Utterly stupid looking.
Oh, and I almost forgot to mention- that extra 800lbs of equivelant weight that you're adding to the vehicle? You're going to have to slow it down, too. Good thing the Mazda3 has awesome brakes, cause you're going to need every ounce of them to stop your car in just routine traffic.
Here's a link for you to read:
Plus-sizing for dummies: a dozen reasons not to go bling-bling with large wheels.<<<< MZ6ZoomZoom:
Quote from: crossbow>>>>
Any increase in unsprung weight is multiplied by a variety of factors.
Did you know that a mere 2 lb increase in tireweight on a 19 inch diameter tire is equivilant to 200 lbs of additional static weight?<<<<
Quote from: crossbow>>>>http://www.mazda6tech.com/index.php?option=content&task=view&id=16&Itemid=32
And here's the direct formula.
http://www.mazda6tech.com/files/rotational.xls
Its quite accurate based on 1/4 and 0-60 times. Having experienced the opposite effect on my car (dropping 40+ lbs of unsprung weight), I can definitely say unsprung weight is one of the most important aspects of a cars performance. Combined with proper tires, it has the ability to make or break what makes a car great. Heavy wheels and tires make the car feel slow, the steering heavy, reduce braking performance, acceleration, and the overall effect of suspension on the car.
Lightweight wheels and tires (smaller diameter then stock, lower profile rubber, lightweight forged wheels), make the car feel hundreds of pounds lighter then it actually is, give a very light steering feel (feels nimble as hell), and increase braking performance, acceleration, and require the suspension to do far less work to maintain the car's manuverability.<<<<
Quote from: crossbow>>>>Remember that though you can maintain the same overall ratio, you are still pushing the tire weight further away from the center of the wheel hub. Because of rotational inertia (insert smart math forumla's I don't understand here), this means that even if you have wheels of identical weight, your still increasing the inertia (and torque required to turn the wheel) by 6-8% (per inch of additional wheel diameter).
So technically to maintain the exact same performance specs (And its effect on unsprung weight) while increasing grip/aesthetics, you'll have to REDUCE the weight of the larger wheels over stock. Aka if you went with a nice set of forged SSR GT2's (18x7.5) which were around 18 or so lbs, its possible to maintain the exact same or better characteristics as a stock configuration while increasing aesthetics.
Because of rotational inertia, the importance of tire weight becomes absolutely critical on a 19 or 20 inch wheel. (Because its on the outside of the rotational mass) A mere lb of additional tire weight can have a drastic effect on the car.
Article on Unsprung Weight and Rotational Inertia
http://www.mazda6tech.com/index.php?option=content&task=view&id=16&Itemid=32<<<<
that's a good read.
but i dont have the money for 20-22" forged lightweight wheels lol i was actually thinking of getting lightweight wheels instead....but yeah i like my stock ones..
i spoke to tadashi, i think i'm going to go with the technosquare tune and a new y-pipe, then leave the fx alone for a bit (except the light tail tints)
i mean im in school anyways
You said you think you are doing that. If the Cobb won't work then no thinking is required haha.
yeah im doing the TS now, no more thinking required besdies finding a y-pipe. I spoke to Tadashi though and he said he can tune it "with" the Y-pipe specs dialed in but i dont necessarily have to have the y-pipe right away. Example: if i get it tuned w/ ypipe specs, he sends it back to me, i run it without the y-pipe yet. it's perfectly fine, i just need to get the y-pipe eventually. So like I said, tune first, then y-pipe, then done for a while with nickel and dime "performance" mods.... gonna save up for something worth it.
Your education is paying off boss.
hopefully this wasnt meant as an insult.
---------- Post added at 04:57 PM ---------- Previous post was at 04:33 PM ----------
this sucks..
i cant find a nismo y
kakumei has no fx ypipes on it's ebay site
