Nightkidz_FX
looks great, so just the fronts for now? Im planning on the same thing
Yeah. I wish I can do the rear too. but the rest of the money will be on my new laptop for now.:.smile:
using the bolts from the stop tech line kit, anyone can do this.there short enough that they don't even need to be cut, just ream the tip slightly.. if you can't do this then have whoever is installing them do it, or anyone who owns a drill... just print out these pictures & say "the bolts need to be drilled at the tip like this"... anyone who can't do this has no business touching your brakes... this is as simple as it gets :
make sure you blow out the passage ways of metal shavings residue after, it's that easy.... aside from this simple "mod" the fronts are 100% bolt on
^^^they are going to weight the same ~
I read Rookie said he seen a 2 piece rotor for the g37/fx50 .... should be pretty pricey
so $1400 for all four corners......... what is the price of the stock rotors when you're ordering from joe? does anyone know off-hand? might not actually be a bad upgrade if the OEM rotors are expensive - not a bad upgrade either way, but, you know what i mean.
i tried to input the part numbers on infinitiparts but it doesn't even have anything listed on there yet for the 09's brakes.
2 INF 43206-JL00A / Rotor Brake – can get aftermarket instead of these, but must be fx50s specific rotors, g37's will not work without modifications that are beyond the scope of this guide, but can be done with some custom work… / MSRP $93.18 / infinitipartsusa.com $69.89 / total = $139.78
Hey Ron:
Total Front + Rear Kit = $2,455.32
That's the cost for all 4 corners. I have all the parts listed and the prices as well if you go back one page I think. The OEM rotors are not expensive at all.
The part numbers should work on that website, that's how I got all my pricing in addition to Turbo's PDF's.
i was referring to the aftermarket 2 piece rotors - not the entire conversion.
---------- Post added at 06:40 AM ---------- Previous post was at 06:35 AM ----------
also mechant.... i completely forgot that the prices were listed in that one post. i was scanning through and when i saw the list again i was thinking it was a quoted reply and skipped it completely......
it looks like those would about an $1100 upgrade difference in price, but, won't work since they're g37 rotors.
