- Los Angeles, CA
- 05 FX35 RWD
Sometimes it'll say it on the inside of the rim: ET__ok, cool. How can I find out the offset? Does it say it on the wheel somewhere?
You mean 285/45/18 for the front and 285/55/18 for the rear? it should be ok as long as its not a huge difference. You can also go wider in the rear. like 275's for the front and 285's for the rear.
You could have different size tires and get away with it but I would recommend just going with one spec. Stick to the 285/55/18. Since the wheels are not a staggered set-up there is really no need to use different size tires.
For those specs, tire rack comes up with these tires.
http://www.tirerack.com/tires/Compa...20&pagenum=1&pagemark=1&x=85&y=14&RunFlat=All
All good tires. I have the yok advan ST on my nismo's.
I would just leave the silver color as it is cause it gives contrast. I'm not a fan of color matching. Black would be better if you really wanted a different color.
Cool Carlos. I'm sure they will turn out great. Let us know how it goes. Glad to help out.
In July. Check the track date thread its listed there for the whole year. Btw...no paintball for you? I guess your going to the stillen meet.
Yeah, most def I will be going to the Stillen meet. No other FXers going?
