- brooklyn, ny
and the reason is.... ?
Those sticks each have 3 SMD's around them, right on the circuit board.
Now that I recently learned of the reasoning behind the Infiniti amber I do appreciate it a little more. At least they didn't just pic one of the ugliest colors for no reason I guess.
I have a week vacation coming up and planning on doing light upgrade..for my tach and speendometer, i'm thinking of leaving in the original bulbs instead of replacing them with LEDs and removing the orange film and putting in a dif colored film.now for the stereo buttons i will have to change them to dif colored LEDs all together... Can someone help me out with a list of exactly everything i need from A-Z in order to complete this job. What LED's do need and tools for example what kind of solder do i need what type of solder wire, ect... thank you..
there is also another way to adjust the intensity of the bulb. i haven't looked at this example personally but i know from my line of work, and from my previous ride. if you follow the traces on the board from the LED, you will surely encounter a resistor. this resistor is what is really setting the current through your LED, which controls the brightness of the LED. make this resistor larger would provide you less current, and less light output, making this resistor smaller obviously provides more current and more light from your LED.
I think i have a too low intesity right now on those 0805's but what i do not understand is that when connected right they still should go on even when it is just less light they still have to do it.
Now mounted a plcc2 in blue wich is much bigger just to try it out. Barely couldn't solder it but it does work and has an higher intensity then the 0805's i have.
Point is that these PlCC2 won't fit in the area's around the volume and channel button'sotherwise i just have taken those.
they have polarity (anode and cathode) are you sure they are in right?
just wondering if the dash light dimmer knob can be turned to max to get more voltage to the LEDs for you?
