I have done the LED conversion on a Accord before and had to rebuild the "bulb"
there is a write up here
http://www.ledautomotive.com/HowToGuides/98-02Accord/DashLEDHowToAuto.asp
[FONT=Arial, Helvetica, sans-serif] Bulb To LED Conversion [/FONT]
[FONT=Arial, Helvetica, sans-serif] Now we need to take all of our bulbs and convert them. Remove the stock bulb from the base by unwinding the two contact leads. You might need a used staple or something to pick the leads up from the grooves.[/FONT]
[/FONT]
Now pull the bulb out of the plastic holder and insert the LED through the holes.[/FONT]
[/FONT]
Note which side is the anode and which side is the cathode. Unlike regular bulbs, LED's are polarized and will not work if you plug them in the wrong way. The anode is the + lead and is longer than the other. [/FONT]
Bend the negative (-) lead so it goes into the groove. Bend the positive (+) lead 90° from the other groove and cut both leads so that they do not stick out past the bulb holder. It will help if you can bend the positive (+) lead slightly toward the end. (See right picture.) [/FONT]
[/FONT]
Solder[/FONT][FONT=Arial, Helvetica, sans-serif] one end of the wire (included with your kit) to the the negative (-) lead and wrap the wire around the bulb holder in the groove. The wire will go where the contact leads on the stock bulb were before you removed the bulb. Cut off any extra wire an put the end of the wire in the groove. [/FONT]
[/FONT]
Take another piece of wire (included with your kit) and bend it in a "U" shape an put it on the bulb holder as shown in the left picture. Cut one of the ends short enough so it will fit down in the groove, and bend the wire into the groove. Next cut the other end of the wire and fold it into the same groove. It is OK if it overlaps the other end of the wire as seen in the picture on the right. [/FONT]
[/FONT]
The left pictures shows what it should look like. Place a resistor (included in your kit) between the LED lead and the wire you just wrapped around the bulb holder and solder both sides of the resistor. [/FONT]
[/FONT]
Here is a diagram that shows the layout of an LED correctly installed.[/FONT]
[/FONT]
*Important!* - While soldering, do not hold the soldering iron to the LED lead, resistor or the solder joint for more than 3 or 4 seconds. If the solder does not make a good contact, wait until it cools before heating it up again. If you hold the soldering iron on the solder joint too long, the resistor and/or the LED will become useless. The resistor will go out before the LED will, we have included extra resistors in case you need them.[/FONT]
A trick to help you solder the tiny resistors on the bulb holder is to use your pliers to hold the bulb holder. Put a rubber band around the handle so it holds the bulb holder and use your tweezers to hold the resistor into place with one hand while you solder it with the other hand.[/FONT]
[/FONT]
[FONT=Arial, Helvetica, sans-serif]Not sure if the Fx uses the same bulb holder, but at least gives you some ideas hopefully.[/FONT]
[FONT=Arial, Helvetica, sans-serif] [/FONT]
