Krayzie
Aérospatiale
- Vancouver, BC
Mobile 1 Full Synthetic 10w30 changed every 6000km
as the topic states, which type of oil do you guys put in your fx?? do you take it to the dealer where they rape you for prices? do you do it yourself?? do you use regular, synthetic, semi-synthetic??
what i can tell you guys, that' i'm getting great results, using 4 stroke engine oil for motorcycles, you may say by your selft , it's this guy crazy ? not, if you compare both oils and engines, the quality need it for maintain a motorcycle working at 18k rpm and also the heat of the engine is higher if you compare from the temperature and rpm range of a vehicle. Results;? better viscosity! high protection to the frictions and better power and aceleration results.
Brand= Spectro
Type=0w40 full syntectic
Made in= USA
I haven't changed my oil yet, over due now, I have no idea what the previous owner used, is there any problem using synthetic on a motor with 55k that may have not used synthetic prior?, I've heard rumors that synthetic should be used from the begining, & not switched to on an older motor, any ideas or opinions on that?
FYI, From what I've been told, 30 should be your highest weight used. 40 tends to get too thick for our lube system as it gets heated up. I've been told it's not designed for that heavy an oil. Take it for what it's worth though. Might just be another myth.
BTW, Welcome to the Scene!
Looks like you chage the color of your wheels? if you does look s like you painted with Dark GUM METAL color? if it's can you tell me the color code you use, i tried but i can't match the same color, i did the painted but is not entirely equal of what i'm looking.
Regards,
Royal Purple with a baldwin filter every 5500 miles![]()
does any of you test any 5 -20w or 0-20w full synthetic oil?
I use walmart's full synthetic 5w30, changed every 5,000 - 7,000 miles. You guys who change oil every 3,000 miles, it's safe to go an extra 1,500 on regular oil and 2,500 - 4,000 on full synthetic.
