- Austintatious, TX
- Name
- Sj
so all in all we're doing this 3 times. that's sounds like a long interval as i drive 900 miles a month!!!
So let me get this straight.
My 04,FX35 is on ramps in order to get the bucket under the radiator to catch old tranny fluid.
Start car and as I'm filling with the new $10.45 per qt of ATF I'm also draining the old ATF.
Once the drained fluid reaches my 10qt mark on the bucket I pinch it off. Finish filling with the remainder of the new ATF.
Reconnect the radiator lines and check Trans fluid levels.
All should be fine
Right??
Just make sure you disconnect the return line from oilcooler to the tranny, as only then you are flushing the oilcooler.
That is the reason why it is so complicated, any debris most likely gets stuck in there and then you give it the chance to come out.
And i don't believe that the tranny will care about a complete fill of new oil.
Why it will get a "shock" from new oil as this oil is specially for this gearbox?:confused.:
This sounds like the best and easiest way to do it...
quoted from g35driver:
I am overdue for this.
I had my tranny fluid changed last month. Me and my buddy did it with the car on the hoist. We used the drain plug on the tranny oil pan. Drained out about 4~6 qts. Then we filled another 4 ~ 6 qts back to the oil pan (depending on how much you drain out). The turn on the engine, with the brake on, shifting from P to R, to D, then D to R to P, each gear stays about the 20 secs to let the new fluid to mix out with the old fluid. Then we did the process again. After that test drive the car in manual mode for about 10 mins. Then measure the fluid level. If not enough, then top out from the tranny dip stick tube with a thin tube funnel.
I do my tranny fluid change about every 30k miles. The car is running fine, no issue with the tranny.
So if you drain the fluid from the plug how much will you need to put in there? Same amount as drained or a bit more?
Gotta fill and check (add or not add) with the engine running.
Hey guys, im wondering if you guys had issues after changing the tranny fluid. Basically the mechanic drained from the plug and added to appropriate level, got the oil from the dealer. I changed it around 62k and now i have 73k. My downshifting is not smooth anymore, rough shifting under 50mph and the car jolts forward. Some say dont touch the tranny fluid, some say do. Im starting to think if i should of changed it at all... Hmm i havent really abused the car to shift this way...
So just to do drain from plug and fill I'll need 3 qts, but buy 4 just in case correct?
