Whats up Rookie?!?! Heard there was another site you had been posting on but never had a chance to check it out until today. Looks good.
Anyway, I ordered a set of the H&R springs to finally lower my FX but I'm worried about a couple things. The first is whether I may need one of these camber kits and the longer bolts and the other is whether I will be rubbing? I have the 22" Black Ordens which I believe has a +18 offset. I was running the Pirelli 285/35/22 but due to a bent tie rod or two and possibly some other parts which I don't know yet since I haven't gotten my FX into the shop, I may need to replace either the front two tires or all four!
The reason I say all four is because since I bought these tires back in May for about $260/each, they now tell me that they will run me $355/each to replace!!!!
For that price I am considering a couple of options. The Toyo Proxes for all four installed are on sale at another local tire place for $1090 installed. Or if I still want the Pirelli's I can get a better price for either the 265/35/22 ($200/each I believe) or the 305/35/22 ($260 each) size! Doesn't make sense, but it is what it is. I don't remember is the Ordens are 9" or 9.5" wide, so I don't know if the 305/35/22 will fit and I know they are even shorter than the 285 size I currently have. Can you tell me the width?
If I am going to lower, would I be better off just buying 4 of the 265/35/22 Pirelli's anyway so I don't have to worry about rubbing or will I be okay with the 285/35/22? I would rather keep the wider tires.
Sorry about the long post, just wanting to get some help and answers. Good to see all your useful info again. Might be needing those bolts if I need to get my camber to spec.
