Finally got the EVO-ALL remote starter installed into my 2017 QX70S. For the 2017 or newer, you may have to use the RL1 Red instead of RL2 Red connector as the brake switch wire position is different from earlier model year. The symptom was the car won't start and no brake light as it attempts to start. Also, to turn on the parking. You need to turn OFF A14 Parking Light Control setting using the FlashLink Manger application.
Interesting mention. On my 2012 I actually did swap rl2 to rl1 and was able to get a crank. - however it was long and drawn out. The car started but the starter was still firing for like 3 horribly scary seconds (it's so loud when a starter engages on a running engine) So RL2 is correct for start commands, but doesn't have the correct brake wire. RL1 has the correct brake wiring, but incorrect start command / sequence.
I probably could have figured it out and did some wire splicing / swap to make the rl2 brake signal come in on the same pin as the rl1 and been in business.
