The adhesive they use for the wood veneer doesn't hold up well which leads to the peeling in the first place. It will be replaced for free under warranty with OEM parts so don't worry. Only problem is that in order to fix the cause of this issue in the first place, the dealership will replace the REAL maple wood that came with the car originally with this so called "simulated wood". It will no longer be real, but it holds up better.
I'm at 39K miles and mine hasn't peeled yet (knock on wood) lmfao no pun intended hahahaha
