IF YOU USE AND LIKE THIS DIY PLEASE +1
(THIS MAY BE ONE OF MANY WAYS OF DOING THIS DIY/WRITE-UP, PLEASE FOLLOW THE PROCEDURE YOU ARE MOST COMFORTABLE WITH.)
FRONT SPACER INSTALL
H&R 20mm spacer kit with extended studs.
1.JACK UP CAR AND PUT ON JACK STANDS. (DO NOT WORK ON A CAR WITHOUT QUALITY JACK STANDS!)
2.REMOVE WHEELS
3.REMOVE CALIPERS BY REMOVING 2 BOLTS FROM THE REAR OF THE CALIPER AND HANG ON SPRING WITH A ZIP TIE.
4.REMOVE CALIPER HOLDER BY REMOVING 2 BOLTS FROM REAR OF CALIPER MOUNT.
5.REMOVE ROTOR
6.REMOVE OLD STUDS BY USING A SMALLER SOCKET ON THE STUD AND HITTING WITH A HAMMER.
7.ONCE THE STUDS ARE LOOSE YOU CAN REMOVE THEM FROM THE REAR.
8.WITH THE 20MM NEW STUDS YOU WILL HAVE TO TURN ROTOR TOWARDS THE FRONT OF THE CAR AND PUT IN THE NEW STUDS WHERE THERE IS A GROOVE IN THE DUST SHIELD.
9.TAKE ONE OF YOUR OLD STOCK LUGNUTS AND REVERSE THEM SO THE FLAT SIDE OF THE LUG GOES ON FIRST.. SCREW THE LUG NUT ALL THE WAY DOWN AS FAR AS YOU CAN SO THE NEW STUDS GET FORCED IN.
10.GET ALL THE NEW STUDS ON.
11.PUT ROTOR BACK ON.
12.PUT CALIPER MOUNT AND CALIPER BACK ON.
13.INSTALL THE NEW SPACERS AND PUT YOUR WHEELS BACK ON.
14.ONCE YOU HAVE YOUR WHEELS ON YOU ARE GOING TO TIGHTEN THE LUGS DOWN AND THIS SHOULD FORCE THE REST OF THE NEW STUD IN ALL THE WAY.
15.MAKE SURE YOU TORQUE YOUR LUGS TO AROUND 85 FT/LBS.
16.RETORQUE YOUR LUGS AFTER 60 MILES OF DRIVING.
ENJOY
