- brooklyn, ny
Do you guys think there's a difference between one place to another? Is that something that takes skills? (in terms of wheels/tire balancing)
yes, there is a difference, in equiptment & the equiptment being calibrated AND in the guy doing it... some guys are good & care about what there doing & make a high effort in centering the weight to the position referenced on the balancer & some guys are much more haphazard & careless... those are the ones where you see spin, add weights, spin, add weights, spin, add weights & spin again, add again...... that's because there not hitting the exact center of where the machine indicates weights are needed... if your acurate in your placement it usually takes no more than 2 spins to get it to 0 out... sometimes 3 at most, sometimes only one too. the equiptment itself also makes a difference...
