Vibration issue...
Discussion in 'FX (03-08) - Wheels & Suspension' started by trainerKEN, Mar 21, 2008.
  1. trainerKEN
    trainerKEN iS VIP iS VIP
    okay, so as some of you know.... I bought Shady's Element 22" wheels... I LOVE THEM, BUT, I'm having vibrations mostly between 40-60mph. I called up a wheel shop and told them that I bought some 22s that came off a same car... and now I have vibrations, they told me that most likely a wheel balance should fix the problem... so, this morning, I had'em done, and they're still vibrating :frown: I DO have 15mm/20mm spacers, that I also got from Shady... What do you guys think it is? The wheel balancing today was almost $50, and turned out NOT to be the problem (so, $50 wasted?). I don't wanna keep going around and around trying to figure out the problem (adding up the $$$ spent)... and in the end, something totally overlooked...
    any suggestions?
  2. sgvxcheese
    sgvxcheese Member
    1,123
    Southern California
    infiniti fx 35
    maybe wheel weight came off. happened to me on my vdub before OR a air pocket in ur tire
  3. gto
    gto Track Ready Moderator
    16,505
    536
    Los Angeles, CA
    05 FX35 RWD
    Are you running hubcentric rings?
  4. OP
    trainerKEN
    I don't even know what that is... but I'm gonna call LMS tomorrow and ask. (Shady and I met there, LMS installed them for me)
  5. Psiclne
    Psiclne Guest
  6. OP
    trainerKEN
    LOL, I like how it says at the very top...
    "DO YOU HAVE VIBRATION PROBLEMS ON YOUR NEWLY BALANCED AFTER MARKET WHEELS?"
    which EXACTLY the problem... but they don't have Element wheels under their listing...
  7. gto
    16,505
    536
    Los Angeles, CA
    05 FX35 RWD
    If the wheels are not hubcentric, then they are lugcentric, and prone to possible misalignment at the centers. You can get ring adapters that will line you up properly. I would ask shady about his setup and experience with that issue.
  8. OP
    trainerKEN
    okay, thanks... I'll PM him...
  9. 909FX
    909FX Premium Member Premium
    3,328
    FONTANA, CA
    2010 Honda Crosstour
    hope you get this issue resolved Ken. Those are some nice wheels.
    Funny how we all have FX's, but each FX has it's own personality.
  10. OP
    trainerKEN
    so, Shady just replied back to my PM and said he didn't use any hub rings, cuz it's NOT needed, in fact... it was designed FOR the FX... I guess he worked with ELements on the design of this wheel... He asked me where did I get them balanced... and I told him "Just Tires" around the corner from where I live... and am waiting for his reply...
    Do you guys think there's a difference between one place to another? Is that something that takes skills? (in terms of wheels/tire balancing)
  11. Dr.2K
    11,683
    9
    Santa Clarita, CA
    2005 FX45
    Ken, since LMS did the installation I would call them back and tell them the issue. Did they not do the installation?
  12. OP
    trainerKEN
    They did... I'm gonna call them right now...
  13. Dr.2K
    11,683
    9
    Santa Clarita, CA
    2005 FX45
    If those wheels do not need hub-centric rings then I suspect they need to be rebalanced with some weights.
  14. Psiclne
    Psiclne Guest
    he had them rebalanced yesterday I think and its still happening.....
  15. Dr.2K
    11,683
    9
    Santa Clarita, CA
    2005 FX45
    Hey, you should be resting not on a computer!
    Let's see what LMS says.
  16. OP
    trainerKEN
    hey, Pierce check your PM
  17. Psiclne
    Psiclne Guest
    Right hand still works Doc......:top:
  18. Dr.2K
    11,683
    9
    Santa Clarita, CA
    2005 FX45
    Well that is the important hand right!?!;):LOL:
  19. brown_fv
    hope this works out for you Ken, i really love those element wheels
  20. OP
    trainerKEN
    I hope so too... cuz I really REALLY like these wheels too... I didn't buy them just because the opportunity was there, but also cuz I LOVE the design... I'm gonna do whatever it takes to make them right (unless, of course I end up spending too much $$$)
