Myis300, here is the H8 connector you need, http://www.ebay.com/itm/Connector-P...Parts_Accessories&hash=item5d3df7a7cc&vxp=mtr
---------- Post added at 08:16 AM ---------- Previous post was at 08:12 AM ----------
Here a lamp that you might be able to use, but not sure is the size is the same though, http://www.ebay.com/itm/97-INFINITI-Q45t-Q45-REAR-LICENSE-PLATE-LIGHT-LAMP-A47-/150966994315?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AInfiniti&hash=item232655858b&vxp=mtr
---------- Post added at 08:44 AM ---------- Previous post was at 08:16 AM ----------
I don't recall seeing a DIY on changing the axle, is it about the same procedure as changing the front hub bearing with the exception of dealing with the hub bearing itself. If you can do the hub bearing, you should not have any problem change the axle yourself.
