Lookin sweet Lance. :good:
One of my faves. I too am partial to the gtr look
I need a lift.
Tapa on Note III
Love the Surfer! Keep the 21's!
How spaced out are the 21's? They look a little sucked in to me from that first pic. But since it's from the side I can't tell if it's an optical illusion. I think if they were/looked as spaced out as the GTR's they might look just as good, if not better.
Perfect FX
Camber suck is bad, ride is low enough to play hell with the stance. I am running 35mm spacers in front and 30mm in the rear and it is still pulled in enough to piss me off. Hoping that by pulling the rear up a bit the W/Ts will pop back out.
---------- Post added at 11:04 PM ---------- Previous post was at 11:04 PM ----------
Thank you my friend.
Do you have the SPC bolts in rear? Maybe you could dial out some of the negative camber, every 1 degree would push the top of the tire out ~5mm. But then you may rub if you're slammed. The rear does camber a lot when you drop it, on the max drop, I'm at -3 which looks kind of extreme on an SUV. I had to almost max out the front camber plates so it would match. I think you'd have to raise it a lot to get rid of the camber. I'm not sure about if the camber curve is linear in rear or not, but I don't think so. With H&R's, I was already at -1.7 degrees or so and that's barely a drop. By going down almost 2" more, I only went to -3 degrees.
Man that thing is pretty.
I'm coming up to Seattle on Friday. You want to grab lunch?
And from no smiles to huge grins
Getting better each trip in! Most tuned car ever?
Tapa on Note III
Mainly to and from work! Like to take ot to the strip now.Awesome, that surfer is going places... Need newer and updated pics please![]()
