- Inland Empire, CA
- 2003 FX45
Check your capacity and prepare before you start. The FX35 takes 5 quarts and the FX45 takes 7 quarts. Even the Infiniti dealer screwed this up. I had an oil change done at Infiniti and they only put 5 quarts into my FX45. They sent me out the door and on the road 2 quarts under! Later on, something didn't seem right. I checked the oil and then the work order where it stated the wrong oil change.
There's no secret to my V8. It is stock, has badges, and a 4.5 engine cover. And the mechanic at the Infiniti dealership didn't even check the dipstick afterwards!
I couldn't belive it - screwed up a FX oil change at the dealership! :eek.:
Probably partially my fault. I wasn't at my normal dealership. I should have gone to Metro where I belong. It's all Cheryl for good service now.
MUFC - Don't overfill. You could blow seals. (That sounds kinda funny. You could blow engine seals. It's much different than blowing goats.)
