P
Psiclne
Guest
Tomorrows a Holiday.....Does UPS/FEDEX deliver? I know USPS is closed.
very easy... Just make sure you use an inch/lbs torque wrench.
my inch lb torque wrench goes from 0-200...you just adjust it to the TQ setting you want and you are good to go.
I installed this spacer and drove around a little bit.
I did not reset my ECU. I noticed that the car like to stay in high rev range. Another thing I noticed was that the car does not like 5th gear. It likes to stay on 4th.
How do I know if i have a vacuum leak? Everything seems fine other than the car revving a bit high.
Do you think the car is revving high cuz it's trying to learn the new found power? I got too tired and didn't bother disconnecting the battery. Do you suppose my high revving problem will be solved with an ECU reset?
On the positive note, I do feel like it added some noticeable power, but then again, it might be because the thing stay in high rev range and whenever i hit the accelerator I feel instant power.
If you take off the engine cover you will probably see right away if the previous owner broke a bolt. the threading for the plenum bolts are all at the bottom 1/3 to 1/2 of the bolt (to my recollection, i may be wrong), so when the bolt breaks you can basically take the top part off (which is what happened in my case). you can just look at all the outer and inner plenum bolts and it you see theres a bolt missing (or you can just pull the top off lol ) then you will know he broke a bolt.in for good info. I'd like to do this but need to research what the previous owner did on our FX. Don't want to take things apart to realize he snapped a bolt and did a half-ass repair (based on what he did on the NAV mod, I'm not putting it past him)
I called them this morning for an update and I guess the order never went through. Something about paying from Canada etc. But they have not refunded my accout yet and it's been sitting for two weeks doing nothing.They said I have to go to the bank and do a wire transfer now. If I wasnt looking forward to this mod so much I may be more pissed, but I just want that thing in my engine!!!!
Keemo,
That totally blows... I was so anxious to get this and I think I know how you feel.
I played with the car a bit more after ECU reset. I did the reset by disconnecting the negative terminal on the battery. I can feel a noticeable pick up in the higher rpm (after 4k) and my car is louder in WOT. In fact, my wife bitched at me a bit for making the car even louder than it is. The intake sound is definitely louder than before. I think the ecu is still learning, because it still like to stay in higher than usual rpm and it still likes the 4th gear in local streets.
quote]
ah man!!! now I want it even more...![]()
THANKS MONGO...
I did a pedal reset on the weekend, thanks to Brown's link, and it brought new life back into her.I heard some guys w/ G's are doing this every other week.
Keemo,
quote]
THANKS MONGO...
What's the pedal reset?
i would recommend doing a ECU pedal reset. take a look at this thread for reference on how to do the ECU Pedal Reset http://g35driver.com/forums/showthread.php?t=6526
