- Austintatious, TX
- Name
- Sj
stick with OEM since they do a great job on our FX's
Oh crap I just tried to change my Rotors but I could not get the damn 19mm Caliper Bracket bolts off! Holy crap those bolts are on tight! I even used a extension pipe for more leverage but it still wouldn't budge.. Did you any guys have a hard time with this also?
Mahalo,
Brandon
How many other people have changed there rotors and pads? I purchased some stopttech rotors and SS lines. Im thinking about doing the brakes myself but a little nervous of messing up. How do you bleed the brake fluid since i will be changing the brake lines?
I would not put grease behind a pad. they make a "glue" you can apply behind the pads.... but make sure you get a new brake hardware kit (clips/spring) with every brake job
It's pretty easy bro.. I would recommend for you to use a different color brake fluids so you know when the old one is all gone out of the lines..
---------- Post added at 11:30 AM ---------- Previous post was at 11:25 AM ----------
I use ATE super blue racing brake fluid you can find it on eBay..
Serious? You don't need that special square looking tool to push/screw the piston back in for our rear pistons?
Q: Doesn't the bleeder valve have to be open and then press the brake pedal to bleed the system and make sure that there is no air in the lines?
bumpppp
