"I've been lined up behind high hp AWD cars at the track and if they break it's more often at the launch."
I can see that happening. Did you chuckle?
Check this out though. AWD has four 1/2 shafts, 2 diffs, 2 d.s.'s, the trans & the transfer case. That's a lot of points of interest. I don't know how much the transfer case itself will absorb before tq hits the trans & I don't know what the trans case itself can handle, but it should take some impact off the rear 1/2 of the drive train & trans. I do know Datman had 330 awhp with the stillen blower, which is lots of immediate, down-low type torque. For this reason, my best semi-quasi-forever-learning educated guess would be that the awd might be better off. Cf driveshafts will help absorb the shock a bit as well. My thought's were that because of all that's going on down there, there's more links in the chain, so to speak, & power is diffused among them. I'll email John & see what he says, copy his reply & post it.
My shop gave me some quotes on driveshafts, cf & alum., & also gave me quotes on the 1/2 shafts. They work w/a lot of awd cars & I was told if I put down enough power, I might need'em, the axles that is. Hope not! I would think that sure, at some level of power I'd need'em, but I doubt the rest of the drivetrain, even with IPT's supposed 500 awhp (tq???) trans would be stout enough for the axles to be the week link, though I must say that's what I was expecting when I first starting modding/learning about the fx, for the axles to be the weak link. Shit.
Glad to see things are working out for you JR. Twin scrolls, what, one just wasn't enough then? Some people...I'm kidding.
"Not physically larger, gear ratios are different though. Not sure what other difference there is that would result in higher torque rating. But if you look at the Titan boards, they have pretty much the same issues trying to get the transmission to hold together under high power."
I wonder what does high power mean to these titan guys? I have to look into the titan trans, check their forums, the titan fsm & see if there's something different about it & if it is in fact rated @ 400 ft lbs stock. If it's a dead-end, then that's that. Datman said he had the Stillen around 330-340 awhp w/out issue? Per JR, S.C. @ 6-8, trans. cooler & the transgo sk via s.c. is going to be the way to go for now.
I love the knowledgeable feedback & hope I add something of value to the conversation.
