- Austintatious, TX
- Name
- Sj
When I let the engine idle the transmission oil seem to be at the full level but when I shut it down it was over the "H".
full means overfill. drain some oil for this you will have to turn the engine on, let the engine cool then measure. this time the oil should be somewhere in the middle. you've put a little too much I believe. This time you will drain the oil via the skinny hose connected to the radiator...
